Maintaning wax protection - help please
Metro1288
Hi Guys,
When you notice that your wax is wearing away is it simply a matter of applying another layer or so? using nattys blue.
This would of been after i initially clayed, polished and sealed.
Cheers, Metro
Yes, you should be able to just re-apply the wax. Under "normal" circumstances, you might need to polish twice a year. Of course, "normal" differs between people! :p If you are the type to anguish over the smallest marring, you'll want more frequent polishing. If you are the type that just wants to be sure the red car doesn't turn pink from oxidation then you might get away with twice a year.
bakchoi
would i just apply over it or do i have to use paint cleaner to clean it first? the nattys will be on top of the exp sealant.
make sure the paint is clean and then you can just add another layer :wink:
