D
dads gt
I'm wondering if it is necessary. Would it be OK to just wash the car after swirl removal??? or should I polish to enhance the shine before I apply my LSP's
dads gt said:I'm wondering if it is necessary. Would it be OK to just wash the car after swirl removal??? or should I polish to enhance the shine before I apply my LSP's
dads gt said:thanx for reply...I will be using ssr's for sure
here is my plan of attack... Lc orange pad ssr 2.5
white pad ssr 2.0 to correct haze
polish either PBPP or AIO
sealant EX-P
wax Natty's blue
When I polish do I use the white pad or black???
dads gt said:Thanks Rollingrock..the pads I'm getting are LC ccs 6.5. Yellow being the most aggresive cut and Blue being the finese pad...u probably knew that already![]()
I don't want to use the yellow but step down to the orange and use 2.5 and then 2.0 with the white pad, to correct any hazing, but like u mentioned maybe I should skip 2.0 and use 1.0 with either the orange or white pad and from there use PBPP with a white pad. How is that???
My finish isn't too bad and the colour is Black!!!
I going to have 1 orange
2 white
1 black pad Is this enough pads for the job???
Yellow will def. haze the paint. Esp. noticeable on black. As already stated, it's hard to say without seeing. I've been able to polish out winter marring on my black car with SSR2 and a polishing pad, but I usually have my paint in better shape than the majority of cars out there, so it didn't need as much correction.dads gt said:Thanks Rollingrock..the pads I'm getting are LC ccs 6.5. Yellow being the most aggresive cut and Blue being the finese pad...u probably knew that already![]()
2 white
dads gt said:Thanks for the help guys!!! I will take the advice of trying the least aggresive method, to correct the problem. I was told by someone to hit it with 2.5 with an orange pad and then try to correct the hazing with 2.0 and a polishing pad...perhaps a little to much for my car.
I will tackle this with the advice from the pro's here.... :lol:
Maybe something like this....white with 2.0 and see if this works, if not move up to 2.0 with orange and so on.
So basically the orange pad causes the hazing,,,will it cause hazing with 2.0 or 1.0 , PP
Does the polishing pad cause any hazing???
Thanks again I'll try to get some pics this weekend :lol:
BigLeegr said:Orange pad will likely give you hazing even with something as "gentle" as PwS. Black just shows it more readily.
The polishing pad shouldn't give you hazing unless you
a)don't let the polish break down properly (go too fast).
Maybe these threads will help
http://www.poorboysworld.net/board/viewtopic.php?t=739
http://www.poorboysworld.net/board/viewtopic.php?t=795
Also, check out LittleMissGTO's threads on Black Paint...she is a magician.
On those threads above you can clearly see the "hazing" that SSR3 and a Yellow Lake pad yields. I also explain my process for these situations based on the condition of these particular trucks.
About 5, I'd say. You can go to 6 for some tougher areas, but I don't typically go over 5.dads gt said:BigLeegr said:Orange pad will likely give you hazing even with something as "gentle" as PwS. Black just shows it more readily.
^^^^what is a good speed for polishing???...or does it depend on the task at hand
